Ikelite Port 5502.41 - suit Nikon 60mm macro
Started by VizBiz ·
  1. Good condition.
    I minor mark, but not noticeable in images (see pic).
    RRP $164.00
    Sale $105.00 AUD
    #5502.41 Ikelite 4.125" Flat Port
    For lens less than 4.125" (10.4cm)
    Flat Ports:
    For standard, macro and telephoto lenses.
    Due to refraction flat ports reduce the angle-of-coverage of a lens and at the same time enlarge the image. This makes the flat port ideal when using standard, macro or zoom lenses to shoot small subjects. Note that if a port is long enough to accommodate the full length of a 1:1 macro lens, the lens may vignette when used at infinity. If access to the lens' full range is desired, then select a dome port instead.
