Ikelite strobes with Nauticam housing
Started by billywinter ·
  1. I just purchased a Nauticam housing for my 7D. What's the easiest way to fire dual Ikelite 125's
    and also get TTL if possible? I know they are not the most compatible strobes for this but that's
    what I got.
  2. Thanks, that's very helpful and not too pricey. Do you know if you can connect the 2 ikelite strobes together
    once you run the single cable to the bulkhead?
  3. Don't know what the connector on the housing is, but the Ikelite cord listed is for FILM cameras and older strobes not the current series.
  4. From what I've gathered, E-TTL can not be achieved with a Canon camera/Nauticam Housing & Ikelite strobes. I
    can install a Canon 6pin bulkhead into the housing and use an ikelite sync cord to fire the strobes, but It will have
    to be set mannually.
    Unless someone knows of an option??
