DS125 problem
Started by Dan swain ·
DS125 problem
  1. Hi iv been having some trouble my my DS125 or camera not sure. It wasn't fireing at all but i had a play around and now it fires but only once, if i turn it off and on again it will fire but only once. Anyone had a similar problem?
    Thanks Dan,
  2. Did you try replacing the sync cord?
  3. Yeh i tried it on another set up and it worked fine and the strobe did too. The problem seems to be with the housing or camera .
  4. I had the same problem and it was a sync cord.
  5. Ah ok il try another one the only problem is on on koh tao and theres not many photographers but il try and find one i can try. thanks
