INON SNOOT SET FOR Z240/D2000
Started by alextyrrell ·
  1. INON SNOOT SET FOR Z240/D2000 FOR SALE - £205 including shipping
    Currently advertised on eBay UK at http://www.ebay.co.uk/itm/271162227079?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1586.l2649.
    The must have accessory for underwater photographers - this Inon Snoot Set is designed specifically to fit the Inon Z240 or D2000 strobe range.
    Snoots can be used to block extra diffused light to eliminate backscatter, highlight a subject by illuminating only the subject to give a spotlight effect on a subject, provide directional lighting to show the texture of the subject, etc.
    The Inon Snoot Set contents: Rubber Hood 72, Rubber Hood Sleeve, Step up Ring, W40°Filter LE x 2 , Snoot Tube 10, Snoot Tube 26. PLUS a spare W40°Filter LE & a Mesh Bag with Snap Clip for safely carrying the Snoot Tubes on a dive. The Rubber Hood is securely attached onto your Z240/D2000 strobe via a supplied dedicated aluminium sleeve, which is screwed onto the diffuser mount screw holes on the strobe. The Snoot Hood has a lanyard to attach to the strobe so it cannot be lost.
    Selling as upgraded my strobes to Sea & Sea YS-250 Pro's and the Snoot does not fit this model without modification! The item is in excellent 'As New' Condition with absolutely no sign of corrosion on any of the metal parts. This retails for £255 at Cameras Underwater, so save yourself £50!
    Item located in Thailand, so will take approx. 7-10 days for (FREE) delivery to the UK/USA/CAN/EUR/AUS. Other countries may take a little longer.
    Some sample images using this Snoot are on my website at http://www.dive4photos.com/Gallery/Macro-Gallery.html.
  2. BUMP!
  3. PM sent. :-)
  4. Snoot is now SOLD!
