More Photos of S3pro
Started by james ·
  • 10Posts
  • 10Replies
  1. More Photos of S3pro
    The S3pro was again on display - this time at the CEBIT show in Germany:
    http://www.cebit-show.com/
    Images courtesy of www.letsgodigital.org:
  2. Is it the S3 Pro? Steve over at Steve's Digicams says that he is reviewing the "Fuji S20 Pro."
    confusing.
  3. Yes, it's the S3pro. I think the S20 is a "prosumer" camera.
    Here's another pic c/o letsgodigital.org:
  4. You mean, the S20? (instead of S2, as you wrote)
  5. Whoops, time to have another cup of coffee. Or maybe it was a freudian slip...:-) Let me go edit that.
  6. Is the S3 pro a TTL flash compatible camera?
    Thank you
    Escalar from Spain.
  7. No, Fuji says it will use DTTL
  8. Man that looks close to the S2 sized body....
    Now if I can cram it into my S2 Housing the buying decision will be SO much easier
    M
  9. Hi Paul, welcome back.
    Check out the other photos of the S3pro here at Wetpixel. It sticks out considerably further than the S2 and I'm 99% sure it won't fit in the Aquatica S2 housing.
    It's more of the size of the Kodak ProSLRn
  10. Hi Paul, welcome back.
    Thanks James,
    The Philippines was outstanding. Some of the best macro diving I have ever done... Going to be three to four weeks to process all the images.
    Going to make the decision on upgrading much harder... Ugh...
    Unless Nexus decides to make a housing for it and I will be #1 in line for everything (I still miss my Nexus N90 Master housing).
    M
