FS: ikelite Canon 40D/50D housing, ports, strobes, cables & arms
Started by spon ·
  • 15Posts
  • 15Replies
  1. I have decided to sell all of my underwater camera equipment for a few reasons:
    (1) I could use the money, (2) I don't use it often enough (3) It's a lot of gear to haul on a trip, and finally (4) I am not skilled enough with the camera to take great photos as I was hoping all of this gear would magically make happen.
    I have over $5500 invested and have had it for about 3 years. (prices listed below are retail and what I paid)
    Here is the list of what I have, It's all in great condition and has been used on 4 trips. Everything is ikelite unless otherwise specified.
    • 8” Dome Assembly #5510.45 Dome Assembly (Port Body below) $400
    • Zoom Clamp and Sleeve Zit #5509.28 $20
    • Zoom Sleeve #0073 Zoom Clamp #9059.8 $20
    • Neoprene cover for 8" dome assembly w/shade # 0200.81 $35
    • Port Body - #5510.22 - Port Body for lenses up to 4.000" with Flat or 4.125" with Dome $150
    • Canon 50D & 40D Housing #6870.50 (with maintenance kit) (Pre Nov. 2009 with 3 clamps) $1500
    • Flat Port #5508.45 Canon 100mm 1:2.8 EF USM Macro $200
    • Neoprene Port Cover #0200.5 Covers all ikelite flat ports $20
    • (3) Ball with extended length stem #9571.3 SA-100 2.5cm (1") Ball $25 ea
    • (2) Ball-to-Ball 15cm (6") Arm Extension #0466.62 SA-100 2.5cm (1") Balls $30 ea
    • (2) Ball-to-Ball 22cm (9") Arm Extension (not IkeLite, not sure of brand) SA-100 2.5cm (1") Balls $45 ea
    • (4) Ball Clamp #9571.2 SA-100 2.5cm (1") Balls $40 ea
    • (2) Aquatica TLC 11” Arm double ball $40 ea
    • (2) UltraLight Control Systems (ULCS) AC-CS Ball Clamp $40 ea
    • (3) Ball with DS50, DS51, DS125, DS160 Mount #9571.4 SA-100 3.2cm (1") Ball ... $25 ea
    • ICS-5 Digital TTL Dual Sync Cord #4103.52 $160
    • ICS-5 Digital TTL Sync Cord #4103.51 $100
    • (2) DS160 SubStrobe #4060.1 (one extra toggle pawl kit included) (only one universal charger) $900 ea
    • Pelican 1600 case with dividers $250
    • Quantaray +1, +2 & +4 77mm diopters $70
    - I have boxes and manuals for the 8" dome, port, SLR housing and strobes (only one strobe box found so far)
    - As far as condition goes, the Pelican case is scratched on the outside from travel, but all the dividers are there on the inside.
    - The strobes have a few scuffs on the outer plastic edges, but the lenses are clear and unmarked.
    - The 8" dome shade has a few scuffs on the plastic edges, but the glass dome itself is perfect.
    - Everything else is in excellent condition. Batteries for the strobes hold a charge well.
    - I always remove all the compressed seals for storage and make sure that all have a light coat of silicon after coming home and cleaning up from a trip.
    Ideally, I'd like to sell it all together, but that might not be practical. I'd like to get $3200 for everything. If I sell items separately, I'll likely sell them for ~70% of the prices listed.
    Edited by spon
  2. I'll sell it all for $2800, just so I don't have to start parting it out. Any takers?
  3. I might be into some parts.
    Sendt fra Samsung Galaxy S2, via Tapatalk forum app.
  4. I sold a strobe and a few other parts today. The list of what is left is below (it doesn't look like I can edit my original post any more).
    This can all be yours for $2200 or make me an offer if you are just after a few parts.
    • (1) Ball-to-Ball 15cm (6") Arm Extension #0466.62 SA-100 2.5cm (1") Balls $30 ea
    • (2) Ball with DS50, DS51, DS125, DS160 Mount #9571.4 SA-100 3.2cm (1") Ball ... $25 ea
    • (1) DS160 SubStrobe #4060.1 (one extra toggle pawl kit included) (only one universal charger) $900 ea
  5. I just received my strobe and I have to say Spon is a seriously top notch seller!
    I am leaving to Bangkok this friday and needed some items in a hurry so I asked if he would part some stuff out. He was quick to respond and once we came to an agreement he sent me screen shots of shipping quotes from 3 different companies, allowed me to pick which shipping option I wanted and then set out in a Blizzard to get my package in the mail immediately after I sent the payment. The package arrived in Edmonton, Alberta all the way from Colorado in no more than 36 hours after I sent the payment.
    The strobe I received honestly looks brand new and I can't find the "scuffs" mentioned in the ad. If the rest of his items are in this good of condition you can count on them being practically brand new.
    Cheers mate!
  6. Here is the list of what I have left. Everything is ikelite unless otherwise specified and I have one of everything unless otherwise specified.
    -Port Body - #5510.22 - Port Body for lenses up to 4.000" with Flat or 4.125" with Dome $150
    -Flat Port #5508.45 Canon 100mm 1:2.8 EF USM Macro $200
    - Neoprene Port Cover #0200.5 Covers all ikelite flat ports $20
    - (2) Release Handle Extender (1" Ball) #9571.3 $25 ea
    - (2) Ball-to-Ball 22cm (9") Arm Extension (not IkeLite, not sure of brand) (1" Balls) $45 ea
    - Ball Clamp #9571.2 (1") Balls $40 ea
    - Ball with DS50, DS51, DS125, DS160 Mount #9571.4 (1" Ball) $25 ea
    - Aquatica TLC 11" arm double ball $40 ea
    - ICS-5 Digital TTL Dual Sync Cord #4103.52 $160
    - Pelican 1600 case with dividers $250
    - Quantaray +1, +2 & +4 77mm diopters $70
    Ideally, I'd like to sell it all together, but that might not be practical. If I sell items separately, I'll likely sell them for ~60% of the prices listed.
  7. Ics-5? Is that ikelite dual sync ?
    Sent from a Samsung Galaxy S2, @ Tapatalk forum app.
  8. Yes Triggerfish, that is the dual sync cable for dual strobes.
  9. Is the ball handle extenders reugular lenght ? Looks longer?
    I think ill take the dual sync atleast.
    Shipping cost to Norway ?
  10. yes, the ball handle extenders are the standard #9571.3 part number. It looks like shipping Priority Mail International to Norway is $23. I can likely get the cable and one or both extenders in the same box with the same shipping cost.
  11. Great i will take one extender and ikelite dual sync cable then.
  12. Here is the list of what I have left. Everything is ikelite unless otherwise specified and I have one of everything unless otherwise specified. Prices listed are MSRP.
    - Port Body - #5510.22 - Port Body for lenses up to 4.000" with Flat or 4.125" with Dome $150
    - Flat Port #5508.45 Canon 100mm 1:2.8 EF USM Macro $200
    - Release Handle Extender (1" Ball) #9571.3 $25
    - (2) Ball-to-Ball 22cm (9") Arm Extension (not Ikelite, not sure of brand) (1" Balls) $45
    I'll likely sell the remaining items for ~60% of the prices listed.
  13. do you still have the flat port 5508.45?
  14. yes, everything listed is still available.
  15. sending pm on available ports..
