Sea&Sea ttl converter on Nauticam
Started by escape ·
  1. Anybody using this combo? What do I need? (bulkhead & hotshoe).
    Personally I hate electric wire but friend of mine can't live without it.
    He want to use ttl converter w/ 5dmk3 housing.
  2. I started to use that on Aquatica housing last week.. Based on my land tests and also in the swimming pool It worked very well with my canon wired to couple YS-120 strobes... The only issue I found was for small apertures over f/22 where it usually shows under exposures, so I needed to compensate using the TTL compensation dial on this converter.
    I think it should works on Nautican too if you have the nikonos with 5 pin wired to the bulk head.
    good luck.
