Strobe Connector between PT 20 and Sea and Sea S/N Strobe
Hy Guys,
This is my first tread here so let me tell you someting obout me : I am an
43 year old German diver I am diving since 1999 an I am an CMAS ** diver, my poor school english isn´t so good, but I try....
Since 2001 I am using an C3000z in PT10 for takeing uw pics, the first aren´t very good so I bought a strobe a Sea and Sea YS60TTL/N and I use it with a slave adapter made in Germany by Matthias Heinrichs it is a microprozessor which triggers the strobe exaktly the same time as the internal stobe so it works perfekt even in P modus !. The stay and the strobearms are selfmade.
Since August 2003 I sell them because there are no spezial parts for the digis in small polycarbonate housings. ( now I am at serial number 30 ! )
My newest projekt is the synk connector between the PT20 and the Sea and Sea an the Niconos Strobes using the newest Oly TTL Konverter of
Matthias Heinrichs (it works like the new Ikelite one ) .
One version needs no direkt Contact to the recever (outside the housing) it is sending by IR : The litle cirquit tranfers the TTL flash dates form the Olympus into signals for the Niconos flash protocol, the outside recever triggers the flash in real TTL , you can use it with any Olympus cam with an extrenal flash connection e.g. C4000, C750, C5050, C5060 best of all you are able to use super makro modus with flash !!!
The second version ist an " wire " version that needs a direkt 3 pole wire to the strobe. My prototype of the PT20 connektor is shown at my page
www.mike-dive.de you have to klick at " Projekte "
At " Montagebeispiele " you are able to see my Proline Stay with different
housings and also my MD-Strobe-Arm. All is build in Aluminium eloxiert in english anodisiered ? and stainles steel and PVC
If you have any questions ask I´ll try to answer
Michael
