Ikelite videohousing#6039.01 including Sony HDV HC1e camera PAL or NTSC
Started by fxvideo ·
  1. For sale, a Ikelite video housing incl. Sony HDV HC1e camera. The housing is completly serviced and all O-rings has been replaced, pressure tested till 50 meters. The housing is like new and is complete with red filter. I have 2 Sony HDV HC1e camera's with it, 1 PAL and a NTSC camera. It is up to you which system you like to use. The only thing he PAL camera has is that the touchscreen is darker then normal, the screen is still working and the touchscreen function are still ok. The viewfinder is fine. The NTSC camera is working ok.
    If you are interested I have a Amphibico HM-50 external monitor for sale, this monitor is NTSC. The Ikelite has no connector for a external monitor so you have to make this you self. Don't think that will be any problem due to he plastic housing.
    I you have any question, please let me know.
    Video setup is located in the Netherlands but can be send woldwide. Sending to Houston USA can been for free.
