Gates Sony F55 housing
Started by CheungyDiver ·
  • 14Posts
  • 14Replies
  1. Nope. Not Rouge.
    Its a newly minted prototype Gates F55 housing. Crikey Its here already......
    Maybe tomorrow.
    Edited by Drew
  2. Here is another photo (one of many). The F5/F55 Gates housing seems to have a hypnotic effect on some people :)
  3. Here are some pics from various angles:
    Left side
    Top side
    Right Side
    Internal view of the left side
    Internal view of the right side
    Edited by Drew
  4. Well here it is. After a three week waiting finally a Sony F55 to test fit Gates F55 housing.
    I will just post a few pictures here. Full blog is in this link: http://www.scubacam.com.sg/blog/2013/05/3147/
    post-595-0-58041000-1367752675_thumb.jpgpost-595-0-93047200-1367752706_thumb.jpgpost-595-0-58774500-1367752759_thumb.jpg
  5. F55 and Gates housing continued 1: The top hung bracket is an interesting concept. I guess if the housing has a minor leak the camera at least has a fighting chance. The bracket is a little fiddly to push in to mesh the dovetail gooves. Part of the problem is that weight of the kitted out camera and also no guides to align it. I found fitted the whole thing up side down easier. post-595-0-79200500-1367752992_thumb.jpg post-595-0-36510600-1367753013_thumb.jpg post-595-0-49161600-1367753032_thumb.jpg I am also glad to find that the gear mechanism and system used in Epic/Scarlet or Red One still could be used here. The compactness of the housing has one disadvantage and that is space. I think normal allen (hex) key may have to be shorten to each some of these gearing assembles. Or open up the front port flange. The gap looks a bit tight.
    Edited by CheungyDiver
  6. F55 and Gates housing continued 2:
    The Sony F55 is fairly long when fully kitted with RAW recorder and the new Sony BP FL75 battery. I guess the prototype given to me for test is meant for no RAW recorder. I am sure the final version would have to be a little longer.
    Without the RAW recorder the housing closes nicely.
  7. F55 and Gates housing continued 3:
    The combination is a heck of a nice system for 4K Raw or 2K RAW and HD footage. The camera pumps out friendly to use footage to cheaper media (compared to RED's SSD) to suit your work flow in post.The compactness and the weight will be a boon for travel. The Gates F55 is no bigger than the old Z1 housing. A bit longer may be with the RAW recorder. This system is one serious kit and if you have the cash then this is it. I can't wait for the finished version.
    David
  8. That's the problem, 'having the cash' not only for the housing but for the airfare weight allowances. Don't think it will fit into my carry on bag.
  9. Hi Steve
    Might not fit your particular bag but it will fit inside a cabin luggage. Weight is not too bad compared with housings for Epic/Scarlet.
    Can't argue about the high cost but after all it is a very high end professional kit.
  10. Any idea of how much it weighs?
  11. 10 kg
    I weight it with the 8" dome & port cover on. No camera inside.
    This is still an prototype so the final weight may vary. I don't think it will be much though.
    cheers
    David
  12. Well I thought I might as well try the housing for size in a Think Tank Airport Acc V2. It just fits nicely. Not with the large 8' Dome though. That port is better in a Pelicase and protected with foam.
  13. Part II:
    Some more pictures of the Gates F55 in a Think Tank Bag......
    10 kg of Gates housing on your back. Its not too bad. I even have room for a Mac Book Air.
    Now I have to work out how to carry the camera. Now that's where your other half comes in handy....
    cheers
    David
