RecSea GF2 Housing with 7 - 14 Port, 8mm Fisheye Port and 45mm Macro Port
Started by windwaternwaves ·
  1. Asking price USD 1,200 plus postage.
    RecSea Housing for Panasonic GF2 with multiple Ports
    Ports include:
    7 - 14 Wide Angle Zoom Dome
    8mm Fisheye Dome
    45mm Macro Flat Port
    All Ports and housing in excellent condition.
    If purchased new prices would be:
    Housing USD 1599
    7 - 14 Port USD 949
    8mm Macro Port USD 549
    45mm Macro Port USD 289
    Total price for this system new is USD 3,386
    To confirm prices and see that this is still current stock goto:
    http://www.bluewaterphotostore.com/recsea-gf2-housing%20
    Selling for a steal as I have moved across to a Canon 5D Mk III
    If you are interested in buying part of this set-up please contact me.
    Manufacturer Info
    Recsea GF2 housing
    The Panasonic GF2 is a competitor to the Olympus E-PL2 and E-PL3, and it accepts the same lenses. The auto-focus on this camera is very fast, and the Recsea housing is exceptional. It's very small, very ergonomic and some pros are starting to use this tiny setup as an alternative to larger dSLR systems that have more drag underwater, especially when a lot of swimming and/or snorkeling has to be done.
    The complete system is a great value for what you are getting. One of the main reasons people go for a mirrorless setup is the smaller size. This is where the Recsea GF2 setup really delivers, regardless of the lens, and is one of the reasons this is our best quality choice. We recommend the GF2 over the GF3, because Panasonic actually took away several important features to make the GF3 smaller and simpler. The GF2 is small and simple enough - and without a doubt should be chosen over the GF3. For the smallest possible high-performance mirrorless camera setup in a high-end aluminum housing, the Recsea GF2 is a clear choice.
    Recsea GF2 Features
    * Sturdy precision machined corrosion resistant aluminum and polycarbonate body.
    * Compact and lightweight with depth rating of 60 meters (200 feet).
    * Dual Back Cover O-rings and dual Port to Lens Port O-ring system.
    * Wide range of Lens Ports, Focus Gears, and supported optional accessories.
    * The housing allows complete control over all camera functions
    * Mount adapters are available for 67mm and ST mounts
    * All ports sold separately and are not included with the housing Recsea GF2 Specifications:
    * Compatible Camera: PANASONIC LUMIX GF2
    * Maximum Depth: 60 meters (200 feet)
    * Material: Main Body - Corrosion-resistant aluminum alloy, Anodized. Levers, Dials, Buttons - POM, PC. Monitor - Hard Coat Acrylic; Screws, Springs - Stainless Steel, Galvanized
    * Size (Housing): Approx. 158mm X 77mm X 100mm
    * Weight (Housing): Land approx. 690g (Body only); Fresh Water approx. 320g (with Lumix GF2 Camera and 45mm Macro Lens Port)
  2. Hi, are you prepared to ship to the UK. If so and you can let me know the shopping cost I would be interested in buying the package.
    Ports include:
    8mm Fisheye Dome
  3. Will ship to UK - cap postage at $50 any more and I pay, any less I refund the extra.
  4. Hi that's great. Do you have an email address I can contact you on?
  5. Sold - Thanks Dive Widower for a smooth transaction.
