Cleaning the CCD on an S2
Started by robmcmahon ·
  1. Cleaning the CCD on an S2
    I have been concerned that I have managed to get dust and some other small debris on the CCD. When shooting with a high depth of field using my 60 and 105 mm lens I am getting marks on my images in identical places. With a narrow depth of field most of them disappear ! I have also cleaned my monitor just in case !!
    I have found this link
    http://www.fujifilmsupport.com/faq/tech/cc...2_clean_ccd.pdf
    Has anyone followed this procedure and have any advice ?
  2. Follow the instructions for cleaning the CCD - they are in the manual that came with the camera. I have cleaned mine about a half dozen times.
    You will need to buy some cleaning swabs and fluid - which you can get from most camera shops these days.
    It's easy - don't worry too much.
  3. I've been afraid to do this myself. I found a local authorized Fuji service center that did a complete camera body cleaning with cleaning the CCD for about $28. Turn-around time was 24 hrs. I figured this was worth it for my peace of mind.
    John
  4. Initally I struggled to find the swabs and cleaning solution, I found that Fixation in South London stocked everything I needed.
    I then waited a couple of days to build up the confidence to start the job.
    It was incredibly easy took a little over 20 secs and cleaned away all the specks on my CCD.
    It cost £50 for 12 swabs and a bottle of cleaner vs £25 for the Pros to do it.
  5. addendum
    Forgot to add that I use the instructions from Fuji on how to open and close the shutter, but clean the sensor using the pbase link instructions. The materials for the pbase method costs just a few cents a cleaning compared to several dollars a cleaning for the Fuji-recommended method using the individually-packaged swabs, but the many testimonials on the pbase link swayed me that "skimping" on costs doesn't really mean skimping on quality.
