Light-for-me 3XML Video Light
Started by john70490 ·
  1. It's a bargain for such a light.
    The problem with nearly all manufacturers is that they state their lumen output simply taking the maximum theoretical numbers from led producers...
    CREE XM-L family has several binnings. From their datasheet I see:
    Cree XM-L brightness at 3A
    T5 845-910   lm @ 3.0A
    T6 910-975   lm @ 3.0A*
    U2 975-1040  lm @ 3.0A
    U3 1040-1105 lm @ 3.0A
    We don't know which kind of XM led is there. Assuming is a U3 bin driven at 3A, the 1100 lumen output is at 25°C that is nearly impossible to obtain in a real application.
    Anyway this is a problem of 99% of lights specs out there :) Nobody has a lab to test the real lumen output. Maybe Keldan... but $$$
    For that price it seems a good bargain.
    Edited by Davide DB
  2. Backscatter sent a few lights to be tested by Deepsea, and published a comparison test. It is possible to test but the point is whether it makes economic sense. Perhaps if we had sponsors to fund such tests. It isn't the most accurate test since it's still in air vs water.
  3. Can you control the brightness?
  4. Can you control the brightness?
    No, just one output.
  5. Backscatter sent a few lights to be tested by Deepsea, and published a comparison test. It is possible to test but the point is whether it makes economic sense. Perhaps if we had sponsors to fund such tests. It isn't the most accurate test since it's still in air vs water.
    With respect, Drew, the test is hardly relevant to this thread since the Light-for-me 3XML is not included.
  6. Personally i wouldn't want a set of lights that only had 1 power setting.
    Just my opinion of course, 3600 lumens is a lot of light. When doing macro i usually only have my lights on either 250 or 500 lumens.
    Cheers Pete.
  7. ha ha, one setting on 3600 is very very restrictive.
