Nikon 17-35mm on D800 with Zen 230mm dome - diopter needed?
Started by Alex_Tattersall ·
  • 14Posts
  • 14Replies
  1. Hello,
    I wonder if anyone would have info about using the above lens on a Nauticam housing. Is a diopter required on the lens? If so, which one is recommended please?
  2. I no longer own this lens, but on my D700 used it with a diopter with the Zen 230, usually +2
  3. Thanks Loftus, Any brands of diopter recommended?
  4. My take is that this is really best left to the individual photographer... They should test both setups, and decide what works best for their own situation.
    All superwide rectilinear lenses exhibit some corner softness. Some more than others. 17-35 is about in the middle.
    As you know, some lenses require a diopter to focus behind a dome. 17-35 does not in Zen 230.
    Single element closeup lenses narrow the fov, increase CA, and induce a strong pincushion distortion. They also tend to sharpen up corners. But how important are the corners in most shots?
    Personally, I am tending to not use the diopters whenever possible, as it seems counterintuitive for me to give up the field of view and increase distortion when I don't have to. I'd rather zoom in a bit, or stop down more, in situations where corner softness will create an issue.
    Edited by Ryan
  5. Thanks Ryan
  6. I've made some experiments using Sea&Sea acrylic Dome 8.5-9" + ER 40 on MDX D800 .
    I've recognized some corner distortions but I think that the global quality will be improved simply adding 20mm further on the extension ring.
    I believe that using Zen 230 you have to use the same thick extension ring (60mm) and this is more important than any diopter corrections.
    Obviously you have to forgot the 25cm 17-35 MDF . This the price to pay, but the 17-35 can give you great quality pictures and without diopter you'll not lost the ability to shot up-above water images.
    by
  7. I just bought this lens as I really needed something faster than the 16-35 f/4.
    I think a 70mm ext is what Nauticam recommends, same at 16-35.
    How would anyone compare the two lenses?
  8. I just bought this lens as I really needed something faster than the 16-35 f/4.
    Jack,
    What are you shooting that requires something faster than the 16-35? I own both lenses but am shooting only the 16-35 under water......so far anyhow. I am using the Zen 230 dome.
    Joe
  9. When I was in Mexico earlier this year I had a lot of problems catching focus with the 16-35 in lower viz while shooting sharks and dolphins.
    I like the lens, but found this problematic.
    Jack
    Sent from my iPad using Tapatalk HD
  10. So Jack, are you talking about that extra stop of light 2.8 vs 4.0 for acquiring focus
    not about shooting at 2.8?
  11. Yes, just didn't focus well in lower light levels for me.
    Jack
  12. Hi Jack,
    70mm are good for the 16-35 but probably are quite long for 17-35. As I said, I tried 40 mm with the Sea&Sea 240mm acrylic dome, and the results are good.
    The New Sea&Sea lens chart suggest 80mm for the 16-35, and (you know) the 17-35 is shorter than the 16-35. So I think that 50-60mm are the good compromise.
    Last week I purchased the 20mm extension and, as soon as possible, I'll use the 40+20+Dome 240 with the 17-35 on my S&S MDX D800.
    Now I'm fighting with the second strobe connections ...
    bye
  13. I seem to recall Alex M. reporting a few years ago that the 17-35mm is actually worse than the 16-35mm with his set-up...
