Tamron 90mm VC Macro
Started by Matt Sullivan ·
  1. Does anyone have experience using this newish lens from Tamron?
    Tamron 90mm f/2.8 SP Di MACRO 1:1 VC USD Lens
    it looks pretty nice and i can't find any appreciable difference between it or the canon 100mmL macro except its $400 cheaper.
    It has increased in length so would it now fit in the same port (ikelite) that the canon 100mmL uses?
    any input on this lens is appreciated :)
    thanks
  2. The 90mm VC has been around for awhile... I tried one out on land and it's very sharp. I decided not to pursue one for underwater use because it extends too much in length when focusing which would require a pretty long and large diameter port. I think it extends as much as 2-3 inches, so check to ensure it will fit in the 100mm Canon / Ike port at full extension.
  3. ah i didnt know it extended, so that is a deal breaker right there haha
    thank you, back to the canon 100L it is :)
  4. Hi,
    The Tamron SP 90mm f/2.8 Di VC USD Macro 1:1 is a very good alternative to the others 105, 100, and 85mm macro lenses. I bought one last year, and It is very sharp, and the AF is working very well. I use it with my Nikon D90 in a Nauticam housing. It doesn't extend (internal AF) and it fits perfectly in the Macro Port 60 + 20mm Extension Ring (Nauticam). Here are two recent shoots taken with this combination.
