Housing and tripod issue
Started by cwise ·
  1. Hi there,
    I would like to use my Sea & Sea D200 housing with a Tripod but it doesn't have a screw hole.
    Does anyone have any ideas?
    Thank you in advance :starfish:
  2. I am a beginner and I also want to learn about this. It would be of great help if anyone help me with this.
    _____________________
    location meublée paris
  3. I made a small bar from aluminium. This screws into the base of the housing using two threaded holes that were there already. Mounted on the bar is a small ball that then fits into the standard ultralight system. My tripod is made from Ultra light arms.
    The advantages are that it is easy to use in the water, made from parts at hand, easy to adjust, adaptable for other uses
    Disadvantages: cost and bulk but tbh I had the arms anyway.
    Apologies, I have no photo of the set up but it works well.
