Amphibico fxz1 phenom white balance...
Started by lutfu ·
  • 9Posts
  • 9Replies
  1. hello
    With the amphibico phenom fxz1 housing can I go for auto white balance and turn back to manual again underwater?
    Iit seems like I can't find a way to do so.
    thanks
  2. you have to turn off the camera and then turn it on again to do that.
  3. Thanks a lot,yes that works............also I have an other question, can we seperate the dome part of the 94 angle wide lens to make a cleaning . Is it possible to do? There seems some dust between the lens and the dome, I want to get rid of them......thanks..
  4. Hmm, not sure about that, I have not tried to do that with mine, might be better to send to Aquatica/Amphibico for them to do that professionally
  5. I had my lens replaced a few years back after I bumped into the side of a wreck. I decided it was not worth the risk and got the agent to replace it. So yes it can be done.
    www.maxgleeson.com
    Edited by max gleeson
  6. Thank you guys for the information,best is to send it away I think
  7. Sory !!! An other question.By the way I managed to take the dome element off and managed to clean and replaced it, it was hard work though.
    My other question is how do you place the 2 filters in their places in the phenom bousing, I'm trying to put a macro and a red filter in , but it seems like there is no space for 2 filters at the same time,so why there is 2 filter places in the housing? I must be doing something wrong.....
    Thanks again...
  8. I think you can only use 1 filter with the 94 degree dome port since the retrofit to fix vignetting. I believe you can use 2 filters on the other available port ( macro dome). You could always put the red filter directly to the camera and the macro on the drop down filter. I will put a macro on the drop down and use lights so no need for colored filter.
  9. Thanks guys for the replays
