Best Strobes for Macro
Started by seansrs968 ·
  1. I currently use DS-161 strobes for my macro. I was wondering if anyone has an opinion what would be considered the best strobes to use for macro and why.
    Look forward to your views.
  2. There are a couple of schools of thought that I have heard. The first and probably most common is that smaller strobes are easier to get in position and use for a lot of macro subjects. The other idea is that larger strobes with more power are better to use because of their much better recycle time. I'm in the second camp. I really dislike waiting for the strobe to charge and much prefer my YS-250s to my smaller 100's. The newer strobes improve both the recycle time and power of my older YS-100 units. So it 's possible to get the best of both worlds if you combine higher ISO bodies with better strobe efficiencies. The newer units allow much easier TTL which might also help the first shot keeper rate.
    Probably isn't a "best strobe" for a category of images that large. Like most things in U/W photography, "it depends" is always close to the truth. Where are you shooting, subjects, camera, lens, etc.? As an example, I would use my smaller strobes to shoot nudi's in Lembeh and would put on the big guns to play with Mandarin fish for the recycle time.
  3. Your question depend on the housing you use and if you use TTL or manual exposure,
    If you can use optical triggered strobes in TTL the INON Z-240, or D-2000 are excellent, sturdy strobes and have a lot of accessoires (snoot, diifuser)
    If you use electrical connection then the INON Z-240 work in manual and give you 24 levels of output
    If you use a Ikelite housing with a built-in TTL controlle a Ikelite strobe will work very well in TTL
    if you use your exposure manual then any powerful strobe with short recycle time, fine adjustable output control and small size (for traveling) will work fine
    Chris
  4. I have two Z240 and although I cannot speak for the TTL, I must admit they are lighter, smaller and more powerful. Highly recommended.
  5. I have two DS161 Ikelite strobes currently. Do the z240s recycle fast? I will not be able to use the TTL function in my new Aquaticia housing. Canon cameras will not interface TTL with the Ikelite strobes in that housing.
