Gei in Mah Belly (I mean Dome Port)
Started by jmauricio ·
  1. The substance may form an air boundary layer and interfere with the optical property of the port. It makes the outer layer hydrophobic. Ports are designed for water contact. Several brands of these nano-coating substance is available now I have yet to see if one could work with ports.
  2. neverwet leaves an opaque film on whatever you spray it on. it is not suitable for uw photography
