Red filter for Panasonic 7-14 lense
Started by mdeuerlein ·
  1. Is there a good and easy solution to use a redfilter with the lumix 7-14 lense inside a UW-Housing without tu much handicraft work?
  2. Is there a good and easy solution to use a redfilter with the lumix 7-14 lense inside a UW-Housing without tu much handicraft work?
    In days of old, we would mount (tape) gel filters to the rear element of the lens. With the exposed sensor and short flange to sensor distance of the 4/3 cameras, I don't think I would do this. Have you tried white balancing?
    Bob
    Edited by Deep6
  3. The Panasonic 8mm fisheye has a filter holder on the rear of the lens and it can be fitted to the Pana 7-14 zoom for magic filters and such.
  4. The Panasonic 8mm fisheye has a filter holder on the rear of the lens and it can be fitted to the Pana 7-14 zoom for magic filters and such.
    Good to know. Thanks Phil.
    Bob
  5. Good to know. Thanks Phil.
    Bob
    Yes thank Phil :)
  6. The Panasonic 8mm fisheye has a filter holder on the rear of the lens and it can be fitted to the Pana 7-14 zoom for magic filters and such
    Panasonic PN VXQ1911 about $23 USD if you can find a supplier.
    Bob
  7. The Panasonic 8mm fisheye has a filter holder on the rear of the lens and it can be fitted to the Pana 7-14 zoom for magic filters and such.
    Thanks Phil. I already heard about this.
    But i don't want to buy the 8mm fisheye just for the holder or to change it every time from lens to lens.
  8. mdeuerlein,
    The post above yours has the part number and the US cost, you may want to look into that.
    Phil
