For Sale - Sea & Sea YS-110a Strobes x 2 + Ultralight Arms System
Started by mgerken ·
  1. Sea & Sea YS110a Strobes (2)
    Ultralight Arm System
    •These Sea & Sea strobes have been used only a few times and show hardy any cosmetic wear and are fully functional. They come with the retainer bolt, diffuser silicone and o-ring pic. Also, have 2 fiber optic cables with only one shoe on each.
    •Asking $400/strobe ($600 new)
    •The Ultralight arms also have been used only a few times and have no wear. I have 4 ball clamps, 2-8" arms and 2" strobe arms. Included are the buoyant arm floats that have never been used. (see photo).
    •Asking $200 for entire set (clamps alone worth $140)
    More Strobe info:
    The YS-110α introduces numerous new exciting functions, opening a whole new digital generation. For example, by connecting it to digital cameras with pre-flash function using a fiber-optic cable, the YS-110α can be used in the fully automatic DS-TTL adjustment mode (Digital Slave TTL). Enjoy complete creative control – when you want absolute control over fine light adjustments, you can use a main strobe in DS-TTL mode and a secondary strobe in manual mode or you can set up an advanced lighting system using two strobes in DS-TTL mode. The DS-TTL adjustment function is also available using the light level control dial for fine control of the light amount when taking pictures in DS-TTL mode. You can also choose from 13 levels of manual controls when you do not want to leave the light adjustment up to the camera. The flat, round, 105° beam angle (with diffuser), achieved by the balanced positioning of the 3 flash tubes, and the power of a Guide Number 22 are examples of the excellent performance of the strobe that is sure to satisfy even the most demanding professionals.
    [Guide Number (ISO 100/m) (land)] 22
    [beam Angle] 105°x 105° (with diffuser)
    [batteries] 4xAA A: 6V Ni-MH: 4.8V
    [Number of Flashes*1] A: 230 Ni-MH: 330
    [Recycle time (full)*2] A: 2.5 sec. Ni-MH: 1.9 sec.
    5400K
    5100K
    [Depth rating] 60m / 200ft
    [Dimensions (WxHxD)] 88x115x150mm / 3.5x4.6x6inch
    [Weight] 700g / 24.5oz
    [underwater weight] -10g / -0.4oz
    [Others]
    - Exposure control: DS-TTL, TTL, Light level control dial (GN): 1.4 / 2 / 2.5 / 2.8 / 3.5 / 4 / 4.5 / 5.6 / 6.7 / 8 / 11 / 16 / 22 (13 steps)
    - Pre-flash control: Equipped with pre-flash cancel mode
    - DS-TTL function
    - Slave function
    - Auto power OFF function
    - Over-pressure relief valve
    - LED target light
    Edited by mgerken
  2. Strobes and arms have been sold. TY. -Mike
