IKELITE Mini C-Lite (NEW) Compact Underwater Halogen Torch
Started by holloways ·
  1. IKELITE Mini C-Lite
    The Mini C-Lite is famous with its reputation for being indestructible and trouble free. The Mini-C Lite features a unique folding switch to assure against accidentally being turned-on. The lens is secured by a screw-on cap that is guaranteed unbreakable. A stainless steel clip is provided for easy attachment to any belt. The Mini C-Lite can be attached to most photographic systems for use as a focus light.
    • Size: 3" diameter x 6" or 7 cm x 16 cm
    • Intensity: 7.5 watts
    • Lamp: Halogen 5.0 volt
    • Beam: Concentrated spot
    • Batteries Required: 4 alkaline “c” cells
    • Burn: 4 hours
    • Weight: 18 oz (510 grams) including batteries
    • Depth Rating: 300 ft (90 meters)
    • Ikelite part number #1103
    • Price: $20
    Optional additional mounting clamp (also new): $15 (Ikelite part # 4074.1) allows for mounting directly to UW housing
