Silk Air weight limitations
Started by scorpio_fish ·
  1. Silk Air weight limitations
    According to their web site, the limit is 20kg per person and 7kg for carry-on.
    What happens when we show up with more? Service charge or baggage denial?
  2. We had no problem with weight. No carry-ons were checked for weight. You are still considered international so I believe those may be the domestic restrictions.
    When I was flying out they tried to say I was over limit. That was because I was only checking in for my leg from Manado to Singapore. Once I showed them I was traveling further there was no issue and, they allowed 10lbs extra for scuba if I remember right.
    I also would not suggest trying to check-in for the rest of your flight legs as the line will be long and, I don't believe they are well versed in doing that. Singapore Transfer desks work like a charm...no worries there.
    Airport will be ungodly humid on check-out so dress cool. Also, they will scan your bags prior to you going to the check-in, you will need a band put on your bag so don't forget to get in that line after they scan your bags...right beside the scan.
    Enjoy
  3. If you are on an international ticket, it is no problem, if you are combining with a ticket on points, make sure the airlines have your connecting ticket number. However, there is only 1 carry-on allowed, which is rigidly enforced. They may weigh it. ( 4-5 kilos only: eek). I found it very efficient, with no problems, either direction.
    Marli
  4. One carry one was not enforced with us. I had my camera backpack and my laptop bag. Many other in the group had two bags also. Might have just been a lucky day though.
