INON X2 for 10D
Started by Jolly ·
INON X2 for 10D
  1. INON X2 for 10D
    Hello,
    I am wondering if anybody knows when the housing will be available? Any release date or information?
    What kind of strobe connector will be mounted? Just for INON Strobes (5 pins?) or maybe also a 6 Pin Connector option for Canon guns?
    Is there any information on Dome/Flat Ports planned for the housing?
    thanx,
    Julian
  2. Last I heard, they were targeting a May(ish) release. US release is doubtful. If you can get it translated, this may help:
    http://www.inon.co.jp/cgis/news/img/2004DF...F/X2_EOS10D.pdf
    From the info I've been able to obtain, the housing will not offer a 6-pin synch connection. Rather, it will offer manual strobe adjustments with 12 EV levels controlled by knobs on the side of the housing. Separate controls for the left and right strobes. The housing should be compatible with many existing INON ports (both dome and flat). I'm about due to ask Mark Rupert for another update one of these days.
    Mike
  3. Thank you Mike.
    I did not find any INON Ports on the web. Do you have any url?
    Do you have any suggestion of pricing? More expensive than the Jonah housing?
    Julian
