WTS Nikon D70s, Aquatica, DS-50
Started by Nwcid ·
  1. I just did a camera upgrade so now selling off my old stuff. I am at least the second owner, but I believe I am the 3rd owner of this set up. It is fully functional but in used shape. I have been using this set up just over a year. I tried to get good pics of any damaged areas. I used this set up last on 10-19-2013 and I will post links at the bottom so you can see the pics it took.
    Aquatica D70 housing. I can not find a page with the actual specs on it but here is a PDF of the user manual, http://www.aquatica.ca/en/manuals/d70.instructions.pdf Asking $300
    Dual strobe arms. The lower arms are 5" and I believe are TLC, the upper arms are 6" and are Ikelite. Asking $225 for the pair.
    Dual sync cable. Asking $125
    Ikelite DS-50 strobes. One has serial #63219, the other is #70459. Both have had the battery compartment flooded but work fine. The flooding is has happened from cracked battery door or bad seals. I tried to picture this the best I could. One currently has a clear door and one has the grey door. I have a spare used clear door but it would need to be checked prior to use. When I got this it had rechargeable batteries with it that I never used. I will included the chargers (not pictured). These do come with the ball sockets. Asking $425 for the pair.
    Nikon D70s. There are no lenses with this. This is actually not the camera I got with this set up. My first one had a "card reader failure" so I had to replace it this spring. Camera comes with 3 batteries that are showing their age, but you can easily get a full dive of pics out of each. It has one spare memory card. Come with charger, wires, CD, ext in the box. Also a soft case that fits the camera and card. Asking $225
    Last but not least is a focus gear for Nikon 10.5mm. Aquatica part #18699. Asking $75.
    If you are interested in the whole set up please let me know.
    You can find picks I have taken with this set up on my Facebook, https://www.facebook.com/john.nokes.965 or on my website, http://scubadivesites.webs.com I used an 8" dome port and either a Nikon 10.5mm or 60mm.
    Edited by Nwcid
  2. All prices are OBO. I did the best pricing I could base on what I could find online. I am open to reasonable offers, this stuff needs gone.
  3. For some reason I could not edit my original post. Bump with price drop.
    Aquatica D70 housing. I can not find a page with the actual specs on it but here is a PDF of the user manual, http://www.aquatica.ca/en/manuals/d70.instructions.pdf Asking $300 $250
    Dual strobe arms. The lower arms are 5" and I believe are TLC, the upper arms are 6" and are Ikelite. Asking $225 for the pair. $200
    Dual sync cable. Asking $125 $100
    Ikelite DS-50 strobes. Asking $425 for the pair. $400
    Nikon D70s. Asking $225 $200
    Last but not least is a focus gear for Nikon 10.5mm. Aquatica part #18699. Asking $75. $60
  4. Bump with price drop.
    Aquatica D70 housing. I can not find a page with the actual specs on it but here is a PDF of the user manual, http://www.aquatica.ca/en/manuals/d70.instructions.pdf Asking $300 $250 $225
    Dual strobe arms. The lower arms are 5" and I believe are TLC, the upper arms are 6" and are Ikelite. Asking $225 for the pair. $200 $175
    Dual sync cable. Asking $125 $100 $75
    Ikelite DS-50 strobes. Asking $425 for the pair. $400 $350
    Last but not least is a focus gear for Nikon 10.5mm. Aquatica part #18699. Asking $75. $60 $50
    OBO, make me a reasonable offer.
    Edited by Nwcid
  5.
    Aquatica D70 housing. I can not find a page with the actual specs on it but here is a PDF of the user manual, http://www.aquatica.ca/en/manuals/d70.instructions.pdf Asking $300 $250 $225 $200
    Dual strobe arms. The lower arms are 5" and I believe are TLC, the upper arms are 6" and are Ikelite. Asking $225 for the pair. $200 $175 $150
    Dual sync cable. Asking $125 $100 $75 $60
    Ikelite DS-50 strobes. Asking $425 for the pair. $400 $350 $300
    Nikon D70s. Asking $225 $200 $175
  6. Bump. Make me an offer.
