FOR SALE: Gates Underwater Housing Package - Sony HVR-V1P
Started by firefish-2007 ·
  1. GATES UNDERWATER HOUSING W/SONY HVR-V1P + EXTRAS SELLING VERY CHEAP!! Everything is in Excellent condition as I service and clean all equipment regularly and comes with loads of extras. This kit is ready to go for shooting both underwater and topside. This is the perfect set up for industry professionals or any underwater videographer looking to produce high quailty HD films at an affordable price.
    SONY HVR-V1P:
    The Sony HVR-V1P offers 25p progressive scanning, in addition to 50i interlaced.
    In its compact, lightweight, and ergonomically designed chassis, the HVR-V1P camcorder integrates advanced technologies such as the newly developed 3 ClearVid CMOS Sensor imaging system – which is only made possible by Sony’s industry-leading semiconductor technology – and a stunning optical 20x Carl Zeiss Vario-Sonnar T*® zoom lens. Such features ensure operators can make the most of the HDV format quality with an extreme level of mobility, ease of use, and operational comfort suited for any shooting scenario. In addition to HDV 1080i recording and playback, the camcorder also offers DVCAMTM/DV recording and playback capabilities, as well as down-conversion of recordings made in HDV 1080i. These bridges between HD and SD allow the camcorder to be used in any DV-based system, whether it uses the HDV, DVCAM, or DV format.
    And for even greater power, the optional HVR-MRC1K CF Memory Recording Unit (INCLUDED) – which is optimized for use on the HVR-V1P camcorder – streamlines the subsequent editing and archiving processes. Adding this unit allows images captured by the camcorder to be simultaneously recorded to tape and CF. After a shoot is complete, simply remove the CF card and connect to a compatible nonlinear editing system provides quick access to files from the editing software and completely eliminates the time-consuming digitizing process. This hybrid tape and CF Card recording system offers a multitude of benefits for shooting, editing, and archiving operations. This has been customized to fit inside the underwater housing.
    GATES UNDERWATER HOUSING:
    • Durable, "Bulletproof" machined aluminum, anodize finish, and sealed with nickel-acetate process
    • Adjustable Handles let you find the best balance and position for your hands on the controls
    • Reliable Mechanical Controls means no sticky buttons or faulty electronic controls
    • Internal Flip Filter provides quick, effortless use of the color correction filter
    • Internal Flip Diopter +1,2 & 4 Great for macro!
    • Interchangeable ports for easy switch between Flat, and Super Wide Ports
    • Quality optics for great clarity, sharpness, no vignetting (cut off dark corners)
    • Gates SWP44 Fathom Imaging Super Wide Angle Port. Anti-reflective coating,120 degree field of view Optical-grade glass elements
    • Gates FP44 flat port (great for macro work with diopters)
    • Gates EM43 External Monitor - a big 4.3" / 110mm color active matrix LCD to assist with framing and focus - even in bright sunlight.
    • DEPTH: 450 feet
    THE COMPLETE KIT INCLUDES:
    1x Sony HVR-V1p w/ECMNV1 monaural electolet condenser microphone
    1x Sony HVR-MRC1K Memory Recording Unit
    1x Sony 0.8X 62mm Wide angle Lens
    1x Sony NP-F970 infoLITHIUM battery (long life)
    2x Sony NP-F570 infLITHIUM bateries
    1x Sony dual battery charger
    1x Sony wireless remote commander
    1x Sony carry case
    1x Kata camera rain coat
    2x 3PK Sony HD 1080p mini tapes
    1x Gates Underwater Sony V1p Housing
    1x Gates SWP44 Fathom Imaging Super Wide Angle Port
    1x Gates FP44 flat port
    1x Gates EM43 External Monitor
    1x Internal Flip Magic Red Filter
    1x Internal Flip Diopter +1,2 & 4
    1x Gates top carry handle
    2x Gates side handles
    1x Pelican Case 1620 w/padded dividers & accessory tray
    All cables, user manuels and spare O-rings, screws etc are all included.
    Item location is within Australia. Please ask for shipping details. Please PM if interested.
  2. I Have a V1P camera. So, I'm interested in everything, but not so much the camera itself. How much do you want?
    I'm also in Aus.
  3. Will you take AU$ 2,000?
  4. SOLD
