which port-extension for the nauticam-rig???
Started by ScT ·
  1. HI everyone!
    New to the Forum I take my opportunity to solve my "Problem":
    My rig is the nauticam-housing for the Canon 550D and the "insect eye port" C60M130 for the Canon 60mm macrolens.
    Now I like to use this port with the Canon 100mm macro USM (non L, non-IS).
    So the question is:
    which portextension (length) do I need for this Combo and the same question when I like to use the 100mm with the kenko 1,4 teleplus 300 DGX - convertor?
    The port-Charts at the nauticam-hp do not show this Combo, but I'm sure they will work - just with which port-extensions???
    I hope sombody can help...
    Best regards, Tom
  2. 50mm will be a touch long, but will accommodate the combo.
  3. Hi Ryan,
    I tryed the 40mm plus 20 mm and this is quite a little bit too short, because the insect-port inside isn't that long as it looks like....
    Any advice is appreciated for my two "problems".... Did anyone try these two combos??
    Greets, Tom
  4. Hi Ryan,
    confusion solved !
    The lens is the same you mentioned; 50mm are perfect!!! And the TK is 20mm so for this Combo 70mm are enough.
    Thanks for your Input!! :dancing:
    Tom
