SOLA 1200 - $425
Started by holloways ·
  • 11Posts
  • 11Replies
SOLA 1200 - $425
  1. Light and Motion SOLA 1200 Underwater Dive Video L.E.D Light
    Sola 1200 Video Dive Light, black travel case, charger and mounting kit. MSRP $700. Selling for $425
    See pictures attached.
    SOLA Description
    Sola dive lights, by Light and Motion, have a factory sealed body = no flooding worry.
    Control is accomplished with a magnetic slider on the top of the body. Slide forward or back to turn on. Hold forward or back to turn off. Rotate to lock. Smart Dashboard: Three indicator lights behind the bezel report battery status, output setting, and charge status; slide forward to increments the power levels. Sola Dive 1200
    • Output: 1200 Lumens Flood, 500 Lumens Spot
    • Beam angle 60 degrees flood/12 degrees spot
    • Run Time: high = 70 minutes, Medium = 140 Minutes, Low = 280 minutes
    • Charge Time
    • Battery: Rechargeable built-in Lithium Ion 2 cell
    • Charger: 2 Amp
    • Dimensions 56 mm x 102 mm
    • State of the art ultra bright L.E.D (Light Emitting Diode Technology)
    • High Intensity White L.E.D. light travels farther underwater for maximum visibility and truer colors
    • Shock and Impact resistant L.E.D. bulbs
    Compatible with the following mounting options (not included):
    • D-Ring Kit
    • T-Handle
    • Pistol Grip
    • Video Locline Mount
    • Photo Ball Mount
    • YS Mount
    Light and Motion is the first dive light company to test and certify their lights in accordance with the ANSI/NEMA FL-1 Standard.
  2. More pictures
  3. You said it had a mount kit. Which mount? ball mount? no photos show the mount side.
    Edited by AllisonFinch
  4. post-4110-0-75490300-1384746262_thumb.jpgpost-4110-0-03714400-1384746293_thumb.jpgThe SOLA is now a stand alone. You'll be buying the SOLA, CASE and CHARGER. see pics
    Hi Allison,
    I'm embarrassed to say - I can't get the mount kit off the video arms. Damn.
    So what does that mean - The SOLA is fine. You'd be purchasing the SOLA, case and charger. You'd need to purchase a mount appropriate for the method you want to use for mounting. (assume $15-$25)
    I'll reduce the price to $400 since there is no mounting kit and you'll have to buy your own for $15-25.
    (I added a few more pictures showing the mounting AREA on the SOLA - you'll see what I mean)
    $400 without a mounting kit - for the SOLA, case and charger
  5. Hi Holloways, I sent you a PM yesterday but maybe you didn't get it?
    I am keen to purchase if you will send to Australia?
    Cheers Pete.
  6. Sorry Pete. As much as I'd like to sell it to you it has a Lithium Ion battery .... which makes it quite hard to ship overseas. Considered a "dangerous good". Probably best to keep it within the USA. I'm open to suggestions - but that is what it looks like to me.
  7. PM sent:)
  8. Still Available - $400 (firm)
    No mounting kit - just the Sola 1200, case and charger. Buy your own mounting kit (to match your rig) for $15-$25.
  9. Why are you selling? Roughly how many dives do you have on it? Sending you a PM
  10. Do you still have this item for sale?If you do I'll take it!
    Harry
  11. Item sold. Sorry - it was a good deal.
