Just curious if the Sea and Sea ys-120's TTL will work using a fiber optic cable attached to the optical sensor on the front. I've been using it in slave mode and keeping it in manual settings but wasn't sure if I should try out TTL. I shoot with an Oly E-PL1 so I usually just keep the flash setting on the lowest power (1/64) to save battery, im sure ide burn through battery faster if I were to use the TTL.
Will S&S ys-120 do TTL using fiber optic cables?
Started by joez2391 ·
- 3Posts
- 3Replies
No, it can't. Ds-TTL didn't come out till the YS110a.
thought I read that somewhere just wanted to make sure, thanks for the help! I guess I'll stick with manual for now
