microFT Video WA Options: 12-35mm, 7-14mm or 8mm?
Started by thetrickster ·
  • 12Posts
  • 12Replies
  1. Looking at options for wreck video with a GH3.
    I'm slowly building my GH3 setup and I'm wondering about ponying up for the 7-14mm instead of using the 12-35mm.
    I had originally thought that 12mm (at 84' AoV) would be plenty, but I'm having second thoughts...
    Both of these lenses can be used behind the 170mm / 7" Zen dome (with extension) but I keep asking myself - is the 12-35mm wide enough?
    I also have the 8mm, but this I think will provide a too wide 'look' and I don't want to get into post and defishing it, as I presume I will lose a lot of quality. (plus I would need a 4.33" dome)
    Anyone got any videos underwater with the 12-35mm at 12mm???
  2. Hi,
    this question has been answered several times :)
    I think that the 12-35 isn't wide enough. I have both 7-14 and 8mm and I shot mostly wrecks.
    Your best option is the 7-14mm.
    8mm is nice and I like it's fisheye distortion. The problem is light: with such wide fov it's nearly impossible to cover the entire field. You need very long arms and checking continuosly theyr position on your display. Basically a PITA.
    8mm:
    (cave part)
    7-14mm:
  3. Davide,
    Thank you for your response, I had assumed this had been asked before... but thank you for your time in answering :)
    Firstly.... STUNNING videos... you got a new vimeo follower...
    Your videos have definitely answered my questions and I will be getting the 7-14mm. Shame there is no OIS version!
    I shouldn't of purchased the 12-35mm! Live and Learn...
  4. Thank you.
    Actually the 12/35 it's a nice lens to have for topside shots :)
    Byeeee
  5. BTW which setup do you have?
  6. I haven't dived my GH3 yet, as I'm still waiting for bits for it - and still saving! but all my previous videos has been with a GoPro and E-PL3.
    But my GH3 setup:
    GH3 + NA-GH3
    Ninja2 + NA-Ninja2 Housing
    Zen 170mm Dome (+20mm extension), Nauticam 65mm Port
    Nauticam Flexitray W
    2x Keldan 4V Lights
    Lens (12-35mm, 60mm, 8mm) + 7-14mm :B):
    Off to HMS Hermes (95) in June and hope to have all of it in place ready for the trip!
    Previous:
    GoPro 3 / EPL3
    LFM 900Lms Lights
  7. I have the 8mm, but it can be too wide.
    I also use the Pannasonic DMW-GFC & DMW-GWC conversions lens that attach to the 14-42x or 14 mm lens.
    http://panasonic.net/avc/lumix/systemcamera/gms/lens/dmw_gfc1.html
    http://panasonic.net/avc/lumix/systemcamera/gms/lens/dmw_gwc1.html
    These conversions lens increase FL from 14mm to 11mm using the GWC & to 120 degree angle with the fisheye conversion lens (GFC). This is a good range for shark action,exactly what i was after.
    Both of these work with the 3.5" & 4" domes using the 14mm lens. You need the 30 mm extension ring to use with the 14-42X lens.
    For me this was a lot cheaper than buying 7-14mm lens & 6" dome port (approx $1500).
    If i was starting over again i would prob go the 7-14mm route, but it was a good low cost option for me as i already had the 14-42x & 14mm lens for topside use.
    Edited by Kevster
  8. Kevster, do you know if the wideangle converter fits to a olympus 12mm f2.0 lens or is only for Pan lenses. ? I have recently bought a GH3 and are looking for a lens for wreckfilming, in swedish waters, And i dont really want a fisheye because of the barrel effect.
    Beautiful films David !
    I also wonder if there is any advantages with a fast lens like that oly 12mm f2.0 ? I get more light in but Will it be difficult whith a open aperture when it comes to get the image in focus because the short depth of field ? If I am forced to use a smaller aperture like 6.3 for more dof to get sharp images then its no use/advantage whit a fast lens underwater.Whats your experienses.
  9. I also wonder if there is any advantages with a fast lens like that oly 12mm f2.0 ? I get more light in but Will it be difficult whith a open aperture when it comes to get the image in focus because the short depth of field ? If I am forced to use a smaller aperture like 6.3 for more dof to get sharp images then its no use/advantage whit a fast lens underwater.Whats your experienses.
    Usually I set the aperture of my 7-14mm to F5. It's sharp enough for my taste but it mantain a useful DOF. This tool it's very useful:
    http://www.dofmaster.com/dofjs.html
    The trick is trying to stay hyperfocal as much as possible.
    I guess that using a faster lens you would fall having soft borders or blurred background. I saw a lot of cave video shot with FF camera having extremely soft borders. You end up beyond dome limits.
  10. Thats a cool website! Thanks.... I've learned something today!
  11. Interesting read, thanks for the link.
  12. What is the angle of view for the 7-14 @7 and the 8mm fisheye?
    How does these two compare to a GoPro in wide mode?
    I am also looking into preferred lenses for the m43 format, but haven't decided on a body just yet so I am in no hurry.
