Nauticam Sony RX100, Inon Wet Lenses, extra
Started by dreifish ·
  • 15Posts
  • 15Replies
  1. Upgraded to a DSLR a few months ago and looking to sell old system, wet lenses, and assorted odds & ends. Everything you see here:
    Housing & Tray/Handles
    Nauticam NA-RX100 Underwater Housing for Sony RX100 - $850
    Nauticam Flexitray II with Left Handle and Screws - $115
    Nauticam Adjustable Right Handle for Easitray or Flexitray (screw holes stripped) - $0
    Nauticam Long Hand Strap Compact and Mid-Range Housings - $25
    Ball-head mount for RX100 Housing - $20
    Nauticam LCD Magnifier with Dioptric Adjustment + Nauticam LCD Magnifier Attachment Rails for RX100 Housing - $170
    Wet Lenses
    Nauticam 67mm to Inon LD Mount Adaptor - $145
    Inon UWL-H100 28 LD Mount Wide Conversion Lens Type 2 - $470
    Inon Dome Unit II for Inon UWL-H100 Lenses - $400
    Inon UCL-165LD Close-up Lens - $180
    Red Filter
    67mm UR/Pro underwater color correction filter -$75
    Camera
    RX100, Japanese only menu (can be crossreference with English manual if you don't read Japanese). Flash is stuck in out position (not a problem for use in case) w/ external charger and extra battery -- $369
    Package Deal (discounted) - $2600
  2. Price drop -- $2500 for packaged deal.
    Also willing to consider discounts for a substantial part of the system if there are components you're not interested in.
  3. Price drop:
    Housing & Tray/Handles - $1000 as package
    Nauticam NA-RX100 Underwater Housing for Sony RX100 - $850 - $800
    Nauticam Flexitray II with Left Handle and Screws - $115 - $100
    Nauticam Long Hand Strap Compact and Mid-Range Housings - $25 -$20
    Ball-head mount for RX100 Housing - $20 - $15
    Nauticam LCD Magnifier with Dioptric Adjustment + Nauticam LCD Magnifier Attachment Rails for RX100 Housing - $170 - $150
    Wet Lenses (bayonet mount for easy swapping under water) -- $1000 as package
    Nauticam 67mm to Inon LD Mount Adaptor - $145 - $125
    Inon UWL-H100 28 LD Mount Wide Conversion Lens Type 2 - $470 - $450
    Inon Dome Unit II for Inon UWL-H100 Lenses - $400 - $375
    Inon UCL-165LD Close-up Lens - $180 - $150
    Red Filter
    67mm UR/Pro underwater color correction filter -$75 - $50
    Camera
    RX100, Japanese only menu (can be crossreference with English manual if you don't read Japanese). Flash is stuck in out position (not a problem for use in case) w/ external charger and extra battery -- $369 - $300
    Package Deal (discounted) - $2600 - $2300
  4. Sale pending on tray/handles and wet lenses. Remaining items:
    Housing & LCD Magnifier - $925 as package.
    Red Filter
    Camera
    Package Deal (discounted) - $2600 - $2300 - $1200
  5. Some more pictures of the housing:
    post-42872-0-79808000-1390364873_thumb.jpgpost-42872-0-19361400-1390364875_thumb.jpgpost-42872-0-36086400-1390364876_thumb.jpgpost-42872-0-59005700-1390364877_thumb.jpgpost-42872-0-10286000-1390364872_thumb.jpg
  6. Due to a potential buyer going MIA, everything below is still available. Offering the package for $1100 now.
    Red Filter
    Camera
    Package Deal (discounted) - $2600 - $2300 - $1200 - $1100
  7. Hello,
    How much for the Wide angle lens,dome unit,color correction filter?
  8. hi is your housing still for sale if so id like to buy it please
  9. Remaining items:
    Red Filter
    Camera
  10. sorry it says $925 for both not $950 so ill pay $985
  11. Do you still have the wide angle lens and dome for sale?
  12. Hello,
    So did the lens and dome sell?
    Matt
  13. Hi, Do you still have a LCD magnifier?
  14. Do you still have the Nauticam LCD Magnifier available?
    Enviado desde mi PE-TL10 mediante Tapatalk
