Do you ever shoot without a wet lens?
Started by JDelage ·
  1. (By choice that is...)
    If yes, in which cases do you choose to do that?
  2. Yes. Typically that would be a close up subject that is not small enough to require a macro and not large enough to require a WA lens and still be able to move in fairly close. For example, an anemone or star fish portrait.
    Additionally, a subject that you can't get close to without it swimming off so if you used a WA lens the subject would be too small. Think reef fish.
    Edited by aviddiver.her
  3. Fish portraits do not require a lens usually
  4. Yup. Although the wetlenses are on most of the time due to my subjects being small. If im shooting fish portraits, I check if I can pull it off with the diopters. But if the composition doesnt work, I remove the diopters (usually subjects that are more than a couple of inches long)
  5. What about big pelagic at low depth?
  6. Big pelagic at low depth best opportunity to get close shooting around 18mm equivalent
