Sigma 15mm + kenko 1,4
Started by AndreaS73 ·
  1. Hello,
    I've just tried to use Sigma 15mm + kenko 1,4x with a 4" mini-dome (with Nikon D800). Above water no problem, AF was ok in all the range, but underwater I realized that I couldn't focus at the minimum, and the minimal focus distance got longer than above water of about 8cm. Is it normal? It's due to the dimension/shape of the dome?
    I think to try to use an extension of 1,5cm betweeen dome and housing, should this help?
    Thank for any suggestion.
  2. If you use a tele-converter you must move the dome out the same distance as the length of the tele-converter to keep the dome in the proper placement. This will affect the virtual image and the minimum focus distance.
  3. Thank you, I'll try as soon as bad weather condition will finish here in north Italy...
