UW Video Housing for Canon T2i, Ebay Auction ends tomorrow
Started by Frazier Nivens ·
  1. http://www.ebay.com/itm/121272098824?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1555.l2649
    THIS AUCTION ENDS TOMORROW.
    This Underwater housing ONLY fits the Canon T2i, this housing coupled with a Tokina 11-16mm or wide angle lens will allow for beautiful underwater video, This housing will allow for total control of the menus at the back of the camera, it can shoot limited still photos for doing a manual white balance with a color correction filter on your lens, the colors will be beautiful if you manual white balance your camera and use a CC filter and wide angle lens. THIS HOUSING IS FOR SHOOTING VIDEO ONLY WITH THE CANON T2i DSLR set on video. You also set the camera on 1 min on screen delay and shutdown and turn camera on when loading the camera into the housing. There is no on off switch. All you do to turn the camera on again is press the shutter release and the camera will boot back up again. You can shoot a still photo using the control on the top for a manual white balance setting. This housing sells for $1,200 and there's NO scratches on the dome port, it has X ring seals on the front and back of the housing for security.
    Great housing for surfing or any in water activity.
    Shipping on this housing will run $25-$35 via ground.
