Canon E-TTL 5 / 6 Pins ?
Started by Jolly ·
  1. Canon E-TTL 5 / 6 Pins ?
    Hi,
    I just think about modifying a Seacam Miniflash housing for E-TTL use.
    The housing was originally used with an A-TTL Flash (430EZ) and Nikonos V connector. Normally I would have the connector replaced by Seacam for a S6 connector.
    But I just wonder if 6 pins are really necessary. I count 5 pins on my EX420 flash. There is one more (no. 6?) which tightens the flash into the camera shoe when screwing in the wheel. Is this Pin No. 6? I can not see a contact in the hole where No. 6 is diving in.
    Thank you in advance.
    Julian
