Lightroom clone tool help
Started by bobanderson ·
  1. I used to have two circles on the clone tool in LR, one where the spot to be covered is and one where the new bit of image to be copied over is coming from.
    Sadly, now I just have the destination circle. What have I done to mess this up?!
    Bob
  2. not sure exactly what you mean, did you do an update? I have LR4 and you only get a single circle - the area to be removed. If you just click once over a spot, LR will decide what information to use on its own. If you click and hold on the spot, then drag the circle to another part of the image, this is now telling LR what area to use to fix the spot.
  3. Hi Bob,
    You managed to change the tool overlay setting. Bottom left of the screen, in the nomal display setup for the Develop module. Change it back to "Always" (probaly switched to "Never") and you'll see your familar circles again.
    Have fun,
  4. Does lightroom have Photoshop's infinitely more useful (used with a graphics pad) "patch" tool?
  5. HI Tim,
    The newest (LR5) version does effectively the same thing by allowing the user to drag the circle to define an area (patch) to clone or heal with similar adjustments available.
    I still use PS but very rarely.
  6. Lightroom still isnt up to par with PS on the ability to do things like "content aware" deletion/patchings or non-circular type patching corrections. those appications and stitching keep me having a subscription to Photoshop. Lightroom is catching up in quite a few functions, but not those.
  7. Hi Bob,
    Have fun,
    Perfect, thanks loads. Its always simple when you know how!
    Anyway, much appreciated.
