My Sony RX100II Still rig
Started by Interceptor121 ·
  1. I've been looking at setting up a system similar to yours. Instead of the AD mount, I've ordered the UWL-H100 28LD lens and the Nauticam 67-LD converter. Any reason that this shouldn't work? Why did you go with AD mount vs LD?
  2. If I remember, he use the AD version of the UWL-100 is because it takes lens hood, and he has two UCL-165AD. He also doesn't like 67mm screw for ease of removal under water.
  3. The LD mount works perfectly well and is the standard choice for the RX100. I have this lens but didn't want to put the dome on it as I use it for video. I have a set of AD lenses for close up so now I have two completely independent lenses set ups. What you have bought is totally fine. I prefer the fix LD adapter to the nauticam (see related post on my blog) but that's minor
    This is the post I was referring to
    http://interceptor121.wordpress.com/2014/02/27/which-fisheye-lens-for-the-rx100/
    And this is about the LD adapters
    http://interceptor121.wordpress.com/2013/04/27/wide-angle-lenses-and-adapters-for-panasonic-lx7/
    The UWL-H100 dome does not suffer any alignment problems but the FIX adapter will vignette less than nauticam
    Edited by Interceptor121
  4. Thanks. I appreciate the info.
  5. Tigar Sharp
    Thanks for the posting.
