FS Sea & Sea Nikon TTL Converter III
Started by MigrationMedia ·
  1. This unit is almost new, Used only a handful of times. Needs New Battery but comes with adaptor bracket. asking price $500 ono
    TTL Converter III for Nikon
    This converter is equipped with a built-in TTL PCB that connects a Nikon digital SLR with SEA&SEA YS-Series strobes and uses the camera’s TTL flash adjustment to control the amount of light put out by the strobe. The converter allows quick switching underwater between TTL mode and manual mode from outside the camera. You can use the TTL correction dial after checking the results of a shot in the LCD monitor to adjust the amount of strobe light for the next shot. Because the converter comes with two separate strobe connectors, you can use advanced automatic TTL flash adjustment with two strobes.
    Specifications:
    Construction: Main body: Polycarbonate, Mounting plate: Corrosion-resistant aluminum alloy.
    Controls: TTL mode / manual switch / TTL light adjustment dial (from +1 to -1 in 1/3 increments)
    Battery: CR2 lithium battery (included)
    Strobe-side connector: 5-pin Sync Cord/N, Camera-side connector: Type-N sync cord (5-pin connector)
    Depth rating: 60m / 200ft
    Dimensions (WxHxD): 68x90x75mm / 2.8x3.6x3inch
    Weight: Approx. 320g / 11.2oz (including CR2 battery)
    Compatible housings: DX-S5Pro, DX-D200, DX-D80, DX-D70/70s (with customized connector), DX-D50 (with customized connector)
    Light adjustment recognition: Nikon method (TTL flash adjustment)
    Please contact us on videographersjobs@yahoo.com.au
    Edited by MigrationMedia
