details of Ikelite housing for Oly C-8080?
Started by JPS ·
  1. details of Ikelite housing for Oly C-8080?
    At quick glance on Ike website I didn't find external measures of the housing; how does it compare to PT-023?
    Moreover, did I understood correctly that internal flash cannot be used with it?
    And if Ike is listening, inquiring minds would be interested in latest estimate of availability...
    Br,
    JPS
  2. Yardstick measurement appears to be 7" wide, 10.25" wide with removable handle and tray attached. 6.5" high and 8" front to back dimensions including port, knobs, etc. No provision to open and use the internal flash of the camera. Web site says late May availability which should be possible but............
  3. Thanks Ike. One more questions: any plans to make a port for Olympus wide conversion lens WCON-08D?
    FYI, for other readers, the PT-023 should be 7.24 x 8 x 7.52 inch, so Ikelite is more compact! And hardwired TTL is appealing as well :)
    My next diving trip no earlier than end of June, so there should be time... :(
  4. Port for the WCON-08D is a possibility. Don't know enough about the system yet to promise...........
