Resolution in S2
Started by escalar ·
Resolution in S2
  1. Resolution in S2
    Dear friends,
    Thank you for your help,
    I have realized that if i shoot in JPEG mode, the resolution is allways 72 pixels/inch. Is that normal? Is it enough for printing? I have a consumer camera and the resolution is 300 pixels/inch.
    Wich one is better?
    Thank you
    Escalar.
  2. If i shoot in raw mode it goes upto 240 pixels/inch....
    Escalar.
  3. It doesn't matter how many pixels per inch you have - it's the total amount of pixels that matters.
    When you prepare a file for printing, set the DPI to whatever the printer is set for - usually 300 dpi, but they vary.
  4. Escalar , I think you should buy a book about digital photography and image processing, you ll learn a lot, james told me that and now a few month after having my S2 , tudying the book and make a lot of images in the pool I m very satisfied with the printed results (25*38 cm) shooted in RAW mode and then using CS, it s BETTER as slides with my F100 !
