Coolpix 5000 and DS125
I've got a question for a friend of my : as soon he's using TTL mode with his 2 DS125... the picture are over-exposed !
Any idea/solution to solve that problem ?
Claude
Claude
Yes,
Go into the "Speedlite Options" in the menu and select Variable Power. Dial in -2.0 stops of flash compensation power.
Use of camera in Program mode will provide erroneous results. What housing? Housing with a Nikonos style socket could have quench circuit not operating from corrosion. Any housing could have quench circuit problem from bulkhead to the camera connection.
he's using this settings... and it doesn't work !
What housing?
an Ikelite housing ! Camera is set in manual mode...
Make sure the TTL sensor isn't blocked by something on the housing......it's the little hole between the on/off switch and lens.....if it's blocked partially, the camera thinks the scene is darker than it really is and then overexposes the shot
Beyond that, move the strobes farther out and vary the shutter speed and f stop
I rarely had this problem except with macro shots.......
Could also be sync cord or strobe problem. Following URL shows which conductor is quench to help you testing the cords:
an other information : it seems like that it works as long he's not underwater with it !!! :!:
Any leakage of the sync cord ? I had the same problem with my Ikelite housing, using TTL topside was OK, once underwater, my strobes were on Full mode-getting crazy-
: water in the connections between flashes and cords :?
a bientot , and say to Laurnt he has to buy a S2 ![]()
