Aquatica A7D Housing fully loaded! Motivated to sell!
Started by Jeffrey Honda ·
  1. I am selling a Aquatica A7D housing with pretty much everything you need to shoot wide angle, macro, and super macro photography. Everything is in good working condition. Here are some pictures of the items with a description of any imperfections.
    1) Aquatica A7D- Housing is in good working condition with some minor fading of printing where the buttons are. The viewfinder has a small chip on the inside, but nothing that blocks the viewfinder in the camera.
    2) Macro Port- Used for 60mm & 100mm lenses. Good working condition. The port has some minor abrasions where the MacroMate sits but nothing in the center that would optically effect a picture.
    3) Macro Mate Flip Lens- Good working condition with nothing effecting image quality. Used for super macro photography
    4) Aquatica 28.5 Ext Ring- Used for 100mm lenses. Minor scratches
    5) Xit 404 tripod plate- Used with tripod legs to steady the housing with macro, super macro shooting, wide angle video work. Scratches but noting effecting its performance.
    6) Stix Custom Buoyancy Float- Used to help offset the weight of the housing. New, good working condition
    7) Xit 404 Red Focus Knob- Used to help control focus with your finger tips and to help people with smaller hands. Good working condition
    8) Aquatica 9.25 Inch Mega Dome- Used with Tokina 10-17mm, Tokina 11-16mm, Canon16-35mm, Canon 17-40mm, Canon 8-15mm and other lens. The dome has some small abrasions on the sides of the dome. Nothing that I can find in my pictures. There is a water stain that is hard to see. Its 1mm big towards the front of the dome. It has not effected any of my pictures. It can sometimes effect video if you are pointed towards the sun, in which most particles will become illuminated at that point anyway.
    9) 6 inch Aquatica Acrylic Dome- was used as a backup dome. there is a small knick on the dome that can be rotated to the bottom of the housing and should not effect anything. It has not effected any of my pictures.
    10) 4 inch Aquatica Glass mini dome- Works great for close focus wide angle shots that are in tight spaces. Perfect condition.
    11) Aquatica 16.5mm Ext Ring- Used for all 3 domes with 10-17mm, 8-15mm. Good working condition with surface scratches.
    12) Aquatica 54.5mm Ext Ring- Used with 16-35mm, 11-20mm, 17-40mm, 100mm+1.4tele., 8-15mm+1.4tele.
    13) Covers for all dome and ports
    14) Xit 404 Manta Aquatica Gear- used with interchangeable xit 404 focusing rings
    15) Aquatica Tokina 10-17mm Gear
    16) Aquatica Canon 60mm Gear
    17) Aquatica Canon 8-15mm Gear
    18) Aquatica Tokina 11-16mm Gear
    19) Aquatica Canon 16-35mm, 17-40mm Gear
    20) Fisheye 1000s with 2 batteries and 2 battery Chargers. Interchangeable handles.
    21)Ultralight Sea & Sea adapters x 2
    22) Aqua View view finder- refurbished
    23) Backscatter Airlock system-New. Used to vacuum seal the housing.
    24) Sea & Sea Sync Cords. (Maybe Optional)Sea & Sea YS 250s. Inquire if you are interested
    25) Canon 7d, Battery and Charger
    26) Canon 60mm Excellent cond
    27) Tokina 10-17mm Lens excellent cond. small dent on hood. does not affect anything.
    28) Tokina 11-22mm Excellent cond
    Optional
    Wahoo HD UW Monitor Housing by Backscatter. The cable has just been upgraded.
    Sony Clm-V55 Monitor
    Aquatica Wahoo Port
    The Wahoo has a sun shade. The shade has 3 screw to take it on and off. One of the screw heads is broken off. The screw can be drilled out, but I haven't because it has no effected the use of taking it on and off.
    This is the price that Backscatter would individually charge. I am asking for half of that.
    Aquatica A7D Underwater Housing $3,015.00
    Aquatica Mega Dome Glass 9.25 $1,675.00
    Aquatica 6inch Dome Port $310.00
    Aquatica 4inch Dome Port $699.99
    Aquatica Extension Ring 16.5mm, .65 $222.00
    Aquatica Extension Ring 54.5mm, 2.135 $285.00
    Aquatica Extension Ring 28.5mm ,3.25 $285.00
    Aquatica Tokina 10-17mm Gear $135.00
    Aquatica Canon 60mm Gear $103.95
    Aquatica Canon 8-15mm Gear $137.95
    Aquatica Tokina 11-16mm Gear $137.95
    Aquatica Zoom Gear: Canon 16-35mm F/2.8 LII
    Canon 17-40mm f/4 L USM $131.00
    Xit 404 Manta Aquatica Gear $150.00
    Aquatica Flat Port for Macro $482.00
    Aquatica Rear Port Cap x2 $133.00
    MacroMate Flip Lens for Aquatica Flat Port $599.00
    Xit 404 DSLR Housing Tripod $200.00
    Xit 404 Focus Knob $45.00
    Fisheye LED 1000 video lights x2 $1199.98
    Ultralight Sea & Sea adapters x2 $45.90
    Sea & Sea Sync (2) Cords $200.00
    Backscatter Air Lock System $400.00
    Aquatica Straight Viewfinder $1,269.00
    Canon 7d $1,600.00
    Tokina 10-17mm $669.00
    Canon 60mm $440.00
    Tokina 11-16mm $550.00
    Subtotal $15,119.77
    Ca State Tax $1,247.38
    Total $16,447.15
    50% off $8,223.57
    I am asking $8,220.00 for everything. I will sell the Wahoo with the package for $600 or $800 separate. I am motivated to sell this set up by the end of April and will work with whoever is interested in the gear. Please allow a day or two for communications. I travel for work and do not have access to email a lot of the times. I will be watching closely though. If you have any questions or concerns please let me know.
  2. Just sent you a PM.
    gary
  3. Just send you a pm, recording the Wahoo.
    Best regards,
    Søren
  4. The best offer will be taken into consideration at the end of the month.
  5. Item is sold and no longer available.
