A Circular Experiement
Started by Oceanshutter ·
  1. Hello Everyone,
    I played around with the circular end of the 8-15mm fisheye on a few dives in Komodo. It is kind of fun. I thought motion made it more interesting. The distortion and view of the reef is interesting as well. It certainly isn't something you would film with on a regular basis. Unless you had a specific idea you were going for. I am curious to know if there is a way to make the circle not cut off on the top and bottom.
    Anyway, let me know what you think.
    Dustin
    Or Youtube
  2. If you get a lens is too small for the sensor, you'll get a complete circle...
  3. Curious!!
  4. It has a fun "looking down on the planet" feel.
  5. I liked the effect for some of the clips, (e.g. the turtle and the flat table corals). I didn't like the spinning globe effect that you used a couple of times - had to grip the arms of my chair. But a couple of these inserted carefully into a normal wide-angle sequence would be quite a powerful way of grabbing an audience - as long as you don't make them seasick!
  6. It has a fun "looking down on the planet" feel.
    Thanks Allison.
  7. I liked the effect for some of the clips, (e.g. the turtle and the flat table corals). I didn't like the spinning globe effect that you used a couple of times - had to grip the arms of my chair. But a couple of these inserted carefully into a normal wide-angle sequence would be quite a powerful way of grabbing an audience - as long as you don't make them seasick!
    Thanks for the feedback peter. But I think you are right, in the right circumstance it could be used.
    Dustin
