Ikelite Port
HI,
Does any one knows if Ikeleite have a port that will fit the Nikon 200mm micro len. If not do Ikelite make custom ports?
Regards
KL Kwang
HI,
Regards
KL Kwang
Port measurements are shown on following URL:
http://www.ikelite.com/web_pages/slrport.html
Click on Port Chart button at bottom of the page for most requested lenses.
I inquired several years ago. I was told to send the lens in and they could make a custome port for it. I don't remember the cost, but it was reasonable. No manual focus gear and you MUST cut the tripod collar off.
Never did due. But I have shot the 200mm with an Aquatica housing. Not an easy lens to shoot with.
Revised charts for Nikon and Canon lens ports have been added to the Ikelite web site:
Ike,
I used the 18-35mm ED 3.5 lens with my S2pro and I was able to zoom - no problem - using your standard clamp and gear.
So I am confused about Note 6
PS, thanks for updating the port chart.
Old chart referred to Fuji S1 Pro so I assumed warning would also apply to S2 Pro, proving once again the known results of assuming............
Hehe! Ike, I am doing the try-out and product shots for the 105mm port with manual focus today. This thing is VERY well designed! For info: This port setup does not require ANY gears be installed on the lens. It's so simple - just slide the port on so that the A-M shift collar lines up w/ the silver button and voila - you have manual focus and A-M shift capability. Nice!
