Does anyone know where I can get a Sea&Sea Sync Cord repaired?
One of my cords has developed a really strange problem. It works fine on manual, but when I set the strobe to TTL it quenches instantly with a "good TTL" indication regardless of the exposure, even with the flash tubes covered over. I have continuity checked the cable and there appear to be no open or short circuits. Another cable works fine, and this cable fails the same way on 2 different strobes.
Bruce Dickson
Strange....i am no expert on this, but maybe its the Camera ? Just and idea
Hi
have you done a mesurement of the resistance at all wires, the same ?
this could be the reason of the failure. The quality of the Sea and Sea kables are not the best it is nearly imposible to solder them.
