Ikelite 70d ttl converter
Started by Cerianthus ·
  1. Using the new 70d housing this weekend, I came across a strange problem.
    When I set the in housing TTL converter to manual. The converter switches back to TTL after one or after several shots.
    I'm using 2 ds51s and it happens with both synch cables I have. Never happened on the 20d housing I had And I made sure I did slide the connector on the camera properly.
    Anybody an idea?
  2. I swapped the strobes, reconnected everything and it was ok on tonight's dive.
