FS : DIAB H100 buoyancy foam, 20 x 300 x 350mm, rated to 55 metres
Started by Stuart Keasley ·
  1. I have a load of spare buoyancy foam if anyone is interested, 20 x 300 x 350mm sheets, each sheet will provide >1.8 kg of lift, crush depth is rated at 55 metres so well within range of recreational scuba.
    Full spec on the foam can be found here:
    http://www.diabgroup.com/~/media/Files/Products/Core-material-pdf/H%20March%202014%20rev12%20SI.pdf
    http://www.diabgroup.com/en-GB/Markets/Subsea/Select-the-right-material-for-your-depth
    £15 per sheet inc P&P in the UK
    Pop me a pm if you're interested...
