Help!please!no contact withe left handle L&M bluefin pro oled for canon XA10
Started by reb ·
  1. Hello,
    Sorry if my English is not great ...I've just bought the camcorder Canon XA10 with the housing L&M bluefin pro oled. Since few days,I do not have any contact with the left handle from the housing.So,I can not use the function with the arrows. Please,somebody can help me how to find the solution?
  2. Hi reb, first question, was this a new or used housing? I'm wondering if the housing needs a service, perhaps?
  3. Thanks a lot, for the advice,i 'm going to check it and let you know.
    Thanks you for the advice and i 'm going to check it and let you know...
  4. I've checked and the right handle has the menu .I don t know how i've done that!!!! no contact with the left handle...the handles switched...do you understand what I mean.
    The housing and camcorder have 10 dives when I bought them. Somebody!have a solution?!!!Thanks again for the reply
  5. It is possible that you need to change the batteries.
  6. I had some similar issues just recently.
    The batteries may need replacing or you may have inadvertently moved the IR sender on the inside left hand side of the housing - this will cause some signals not to be sent to the camera properly
  7. Hello !Steve!and Swiftff!
    Thanks for the reply but still not work. The batteries are ok . Steve! I've checked The IR Sender on the Inside but nothing . I'm getting crazy!!! I still not find a solution...
    Rebecca
