Faulty Strobes
Started by bradrk ·
Faulty Strobes
  1. Hey Guys
    SO I have a couple of strobes that are having a little trouble...... when I turn them on nothing happens,,,,,,,,, but if I tap it it turns on...... does anyone know what is going on???? are the capacitors starting to go or is it something else???
    Im leaving for an overseas trip in a few weeks so would love to sort them out before I go.....
    Brad
  2. What kind of strobes, what kind of batteries etc.?
    Bill
  3. Once you answer Bill's questions and get the batteries charged up you will need to reform the capacitors. This done by leaving a strobe on for a while. Thirty minutes for example. Do this before firing them. BTW NiMH batteries die if they are not used, so you may need new ones. This happened to be when I bought a secondhand but virtually unused strobe.
  4. HI guys
    Sorry it has taken so long to get back to you, I have used new rechargeable batteries and seems to fix most of the issue. Tom I will try leaving them on for a while to reform the cap....
    Thanks for your help
    Brad
