Advice on housings Nikon D7000
Started by Chappo94 ·
  1. Currently shooting with Nikon D7000 and have a Ewa-Marine U-BXP100 Soft Underwater Housing, but want to move to something more ridged and control user friendly.
    Anyone have good advice on housing for D7000? (enter level)
    Anyone used this case below or think its any good?
    http://www.ebay.com/...=item417fa972ea
    Thanks in advance
    SC
  2. I would look at a mid level used housing : Aquatica, Sea & Sea, Subal. Try for a complete package - housing, strobe, arms, ......
    Each of these are well made and are from reputable companies, and spare parts are available for periodic overhauls.
    If possible, buy from this board as I believe most, if not all are reputable and the sellers knowledgable..
    The housing you referenced on EBay: what brand is it, are there interchangable ports available, does it have strobe connector/ports, .........?
    Look closely at the various views of it; it is designed the same as a $100 case for an inexpensive point & shoot camera.
    It is only rated to 130 ft - implying it is not very robust. I believe the three I suggested are all good to 300 ft.
    Lastly, you get what you pay for - some times! And you will not get much for $448.
    Good luck
    Edited by okuma
  3. I also would advise against this purchase. You should look at the used market and get something that can be repaired, serviced and upgraded.
  4. PM sent.
  5. Thanks for good feedback
  6. Look for a used Nauticam. You can find them for around the same price as an Ikelite from time to time.
